I guess there is a reason for that being lower, i'm not overclocked to 5ghz, as when it's in use @5ghz , at least during benchmarks, my very small bedroom gets warm in a few hours which im not a fan of, even if the temps under water are acceptable.
Also notice in ur sig RAM says it is @1600 was that to get the timing CAS timing? Could that be why, because this ram is clearly @1866 just curious....?
Strange part is how little my gpu clock goes on this test, yet it is locked at 130fps in a few of the tests and 6000 in others.
Yeah that SSD helps with blueray speeds too
